Installation ins't complete, page lost css?
IIS, Apache
Postby icaroo » Thu Mar 31, 2016 6:03 pm
I'm trying install OnlyOffice Community on my server, I have a Linux Server and a IIS. But they are with the same problem.
After the installation, when I try to access it's seems that the css isn't loading.
I'm using Ubuntu 14.04 and docker https://github.com/ONLYOFFICE/Docker-CommunityServer
Any Suggestion?
Looks like he trying to load
icaroo
Re: Installation ins't complete, page lost css?
Postby Dean » Fri Apr 01, 2016 8:11 am
Please send us the results:
sudo docker ps #pick the id of the Community Server container
sudo docker attach {id} #proceed to the container
ls /var/www/onlyoffice/Data #run it inside the container
Also please specify the exact command used for installing ONLYOFFICE.
Postby icaroo » Mon Apr 04, 2016 7:06 pm
I made a reinstallation and it is working fine now. Following the GitHub description, only Community and Mail Server was installed.
code Mail Server: sudo docker run --privileged -i -t -d --name onlyoffice-mail-server -p 25:25 -p 143:143 -p 587:587 \
-h onlyoffice.cerauto.com.br onlyoffice/mailserver
Code Community: sudo docker run -i -t -d -p 80:80 -p 5222:5222 -p 443:443 --link onlyoffice-mail-server:mail_server --restart=always onlyoffice/communityserver
But some error logs are showing:
/var/log/nginx > error.log
2016/04/01 19:48:45 [warn] 748#0: duplicate MIME type "text/html" in /etc/nginx/sites-enabled/onlyoffice:35
2016/04/01 19:49:19 [warn] 753#0: duplicate MIME type "text/html" in /etc/nginx/sites-enabled/onlyoffice:35
2016/04/01 20:07:34 [warn] 750#0: duplicate MIME type "text/html" in /etc/nginx/sites-enabled/onlyoffice:35
2016/04/04 13:04:41 [warn] 747#0: duplicate MIME type "text/html" in /etc/nginx/sites-enabled/onlyoffice:35
/var/log/onlyoffice > monoserve.log
[2016-04-01 19:48:50Z] Error Could not start server
[2016-04-04 13:04:46Z] Error Could not start server
/var/log/onlyoffice > nginx.error.log
2016/04/01 18:49:40 [error] 784#0: *1 upstream prematurely closed connection while reading response header from up$
2016/04/01 18:49:40 [error] 784#0: *1 connect() to unix:/var/run/onlyoffice/onlyoffice2.socket failed (111: Connec$
2016/04/01 18:49:40 [crit] 784#0: *1 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such f$
2016/04/01 18:49:41 [error] 784#0: *1 no live upstreams while connecting to upstream, client: 10.0.10.110, server:$
2016/04/01 18:49:46 [error] 784#0: *5 connect() to unix:/var/run/onlyoffice/onlyoffice.socket failed (111: Connect$
2016/04/01 18:49:46 [error] 784#0: *7 connect() to unix:/var/run/onlyoffice/onlyoffice2.socket failed (111: Connec$
2016/04/01 18:52:16 [crit] 784#0: *9 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such f$
2016/04/01 18:52:49 [crit] 784#0: *21 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:53:05 [crit] 784#0: *17 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:53:18 [crit] 784#0: *63 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:53:32 [crit] 784#0: *63 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:53:48 [crit] 784#0: *32 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:54:07 [crit] 784#0: *21 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:54:32 [crit] 784#0: *32 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:54:56 [crit] 784#0: *32 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 18:55:14 [crit] 784#0: *32 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such $
2016/04/01 19:19:13 [error] 784#0: *104 upstream timed out (110: Connection timed out) while reading response head$
2016/04/01 19:19:13 [crit] 784#0: *104 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such$
2016/04/01 19:19:37 [crit] 784#0: *106 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such$
2016/04/01 19:29:37 [error] 784#0: *106 upstream timed out (110: Connection timed out) while reading response head$
2016/04/01 19:29:37 [crit] 784#0: *106 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such$
2016/04/01 19:29:52 [crit] 784#0: *117 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such$
2016/04/01 19:34:59 [crit] 784#0: *121 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such$
2016/04/01 19:35:20 [crit] 784#0: *125 connect() to unix:/var/run/onlyoffice/onlyoffice3.socket failed (2: No such$
2016/04/01 19:39:52 [error] 784#0: *115 upstream timed out (110: Connection timed out) while reading response head$
2016/04/01 19:44:59 [error] 784#0: *120 upstream timed out (110: Connection timed out) while reading response head$
2016/04/01 19:45:20 [error] 784#0: *121 upstream timed out (110: Connection timed out) while reading response head$
2016/04/01 19:48:58 [error] 757#0: *1 connect() to unix:/var/run/onlyoffice/onlyoffice.socket failed (111: Connect$
2016/04/01 19:48:58 [error] 757#0: *3 connect() to unix:/var/run/onlyoffice/onlyoffice2.socket failed (111: Connec$
2016/04/01 19:49:32 [error] 756#0: *1 connect() to unix:/var/run/onlyoffice/onlyoffice.socket failed (111: Connect$
2016/04/01 19:49:32 [error] 756#0: *3 connect() to unix:/var/run/onlyoffice/onlyoffice2.socket failed (111: Connec$
2016/04/04 13:04:55 [error] 755#0: *1 connect() to unix:/var/run/onlyoffice/onlyoffice.socket failed (111: Connect$
2016/04/04 13:04:55 [error] 755#0: *3 connect() to unix:/var/run/onlyoffice/onlyoffice2.socket failed (111: Connec$
2016/04/04 13:06:42 [error] 755#0: *7 upstream prematurely closed connection while reading response header from up$
2016/04/04 13:06:42 [error] 755#0: *5 upstream prematurely closed connection while reading response header from up$
2016/04/04 13:18:04 [error] 755#0: *12 upstream timed out (110: Connection timed out) while reading response heade$
2016/04/04 13:35:28 [error] 756#0: *153 upstream timed out (110: Connection timed out) while reading response head$
2016/04/04 13:54:07 [error] 756#0: *158 upstream timed out (110: Connection timed out) while reading response head$
2016/04/04 13:59:28 [error] 756#0: *178 upstream timed out (110: Connection timed out) while reading response head$
2016/04/04 13:59:28 [error] 756#0: *177 upstream timed out (110: Connection timed out) while reading response head$
2016/04/04 14:04:21 [error] 753#0: *199 upstream timed out (110: Connection timed out) while reading response head$
2016/04/04 14:06:44 [error] 753#0: *211 upstream timed out (110: Connection timed out) while reading response head$
2016/04/04 14:06:44 [error] 753#0: *214 upstream timed out (110: Connection timed out) while reading response head$
2016/04/04 14:08:37 [error] 753#0: *217 upstream timed out (110: Connection timed out) while reading response head$
/var/log/onlyoffice > web.04-04.log
2016-04-04 14:58:37,773 ERROR [Threadpool worker] ASC.Web.Bundle.DiscTransform - System.Threading.ThreadAbortExcep$
at (wrapper managed-to-native) System.Threading.WaitHandle:WaitOne_internal (System.Threading.WaitHandle,intptr,$
at System.Threading.WaitHandle.WaitOne () [0x00000] in <filename unknown>:0
at ASC.Web.Core.Client.Bundling.DiscTransform.UploadToDisc (ASC.Web.Core.Client.Bundling.CdnItem item) [0x00000]$
2016-04-04 14:58:37,773 FATAL [Threadpool worker] ASC.Web.Bundle.DiscTransform - System.Threading.ThreadAbortExcep$
at ASC.Web.Core.Client.Bundling.DiscTransform.Process (System.Web.Optimization.BundleContext context, System.Web$
/var/log/onlyoffice > web.api.log
2016-04-04 13:44:10,092 ERROR [Threadpool worker] ASC.Api - method error: http://127.0.0.1/api/2.0/mailserver/doma$
System.ArgumentException: Invalid mx host
Parameter name: builder
at ASC.Mail.Server.Administration.Interfaces.DnsPresets..ctor (ASC.Mail.Server.Administration.Interfaces.Builder$
at ASC.Mail.Server.Administration.Interfaces.DnsPresets+Builder.Build () [0x00000] in <filename unknown>:0
at ASC.Api.MailServer.MailServerApi.get_MailServer () [0x00000] in <filename unknown>:0
at ASC.Api.MailServer.MailServerApi.GetDomains () [0x00000] in <filename unknown>:0
at (wrapper managed-to-native) System.Reflection.MonoMethod:InternalInvoke (System.Reflection.MonoMethod,object,$
at System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder bin$
/var/log/onlyoffice > svcNotify.04-04.log
2016-04-04 12:57:49,122 ERROR [NotifyThread 2016-04-04T12:57:49.0795710Z] ASC.Notify - Tenant: 1, To: icaro@<myemaildomain.com> - System.Net.Mail.SmtpException: Message could not be sent. ---> System.Net.Sockets.SocketException: Could not r$
at System.Net.Dns.Error_11001 (System.String hostName) [0x00000] in <filename unknown>:0
at System.Net.Dns.hostent_to_IPHostEntry (System.String originalHostName, System.String h_name, System.String[] h_aliases, System.String[] h_addrlist) [0x00000] in <filename unknown>:0
at System.Net.Dns.GetHostByName (System.String hostName) [0x00000] in <filename unknown>:0
at System.Net.Dns.GetHostEntry (System.String hostNameOrAddress) [0x00000] in <filename unknown>:0
at System.Net.Dns.GetHostAddresses (System.String hostNameOrAddress) [0x00000] in <filename unknown>:0
at System.Net.Sockets.TcpClient.Connect (System.String hostname, Int32 port) [0x00000] in <filename unknown>:0
at System.Net.Sockets.TcpClient..ctor (System.String hostname, Int32 port) [0x00000] in <filename unknown>:0
at System.Net.Mail.SmtpClient.SendInternal (System.Net.Mail.MailMessage message) [0x00000] in <filename unknown>:0
at System.Net.Mail.SmtpClient.Send (System.Net.Mail.MailMessage message) [0x00000] in <filename unknown>:0
at ASC.Core.Notify.Senders.SmtpSender.Send (ASC.Notify.Messages.NotifyMessage m) [0x00000] in <filename unknown>:0
2016-04-04 15:00:11,750 ERROR [Threadpool worker] ASC.Core.Billing.TariffService - ASC.Core.Billing.BillingNotFoundException: error: cannot find dedicated resources for the portal id '8dbcf8db-a175-427e-b50f-3be1bc76d9e1' Debug info: {$
at ASC.Core.Billing.BillingClient.Request (System.String method, System.String portalId, System.Tuple`2[] parameters) [0x00000] in <filename unknown>:0
at ASC.Core.Billing.BillingClient.GetPaymentOffice (System.String portalId) [0x00000] in <filename unknown>:0
2016-04-04 16:00:11,781 ERROR [Threadpool worker] ASC.Core.Billing.TariffService - ASC.Core.Billing.BillingNotFoundException: error: cannot find dedicated resources for the portal id '8dbcf8db-a175-427e-b50f-3be1bc76d9e1' Debug info: {$
2016-04-04 17:00:11,420 ERROR [Threadpool worker] ASC.Core.Billing.TariffService - ASC.Core.Billing.BillingNotFoundException: error: cannot find dedicated resources for the portal id '8dbcf8db-a175-427e-b50f-3be1bc76d9e1' Debug info: {$
2016-04-04 18:00:11,792 ERROR [Threadpool worker] ASC.Core.Billing.TariffService - ASC.Core.Billing.BillingNotFoundException: error: cannot find dedicated resources for the portal id '8dbcf8db-a175-427e-b50f-3be1bc76d9e1' Debug info: {$
Something that I have to worry about?
icaroo
