unable to install onlyofice community server in windows 10
IIS, Apache
Postby riturajuniyal » Sun Aug 30, 2015 6:28 am
sir
i am unable to install onlyofice community server in windows 10. installer always fails at preparing iis and then reverts back
is there is any work around
thanks and regards
riturajuniyal
Re: unable to install onlyofice community server in windows
Postby Dean » Mon Aug 31, 2015 6:25 am
Please specify - were there any components installed before the beginning of the installation?
If yes, please:
Please, uninstall all the prerequisites and restart the machine.
Start OnlyOffice installation and install all the prerequisites on step2.
NB: If you have some important data in Database don't uninstall MySqlServer.
Postby riturajuniyal » Sun Sep 06, 2015 6:40 am
sir
still unable to install in windows 10 . i have tried installing/uninstalling prerequisites several times but it always give this error "There was a problem in iis updatation your original configuration will be restored" at the last phase of installation .
is there any solution or it cannot be installed in windows 10 with iis version 10.
regards
rituraj uniyal
riturajuniyal
Postby Dean » Thu Sep 10, 2015 11:12 am
Sorry for the reply delay.
Now it is unfortunately impossible to install on Win 10. The only option is to compile ONLYOFFICE from sources, we will send the information to our developers team. Sorry for the inconvenience!
Postby noldor » Mon Oct 19, 2015 8:37 am
I also have the same error.
I'm installing the "ONLYOFFICE_DocumentServer_Win-install.v3.0.exe" on Windows 10 and it goes pretty well until the IIS configuration step.
It says "There was an error during the IIS configuration process" and then rollbacks all installation processes.
Is there any way to install IIS Web Site manually and skip that step? Because after the rollback process, there is still a web site added on the IIS with an error icon named "ONLYOFFICE DocumentServer". And in the next try of installation, it asks me if I want to skip the IIS configuration process. So if I somehow make the IIS configuration manually, I think everything will be fine.
Thank you.
noldor
Postby AnaMih » Thu Oct 22, 2015 2:53 pm
Our developers are working on the solution and let you know as soon as any solution is found.
User avatar
Postby Esowteric » Mon Jan 18, 2016 3:38 pm
Exactly the same here with Windows 10. The installation fails when configuring IIS and then rolls back changes.
Esowteric
Postby santosjoni » Wed Apr 20, 2016 2:37 pm
Any news about this issue? Thanks in advance
santosjoni
Postby santosjoni » Wed Apr 20, 2016 2:39 pm
Any updates on this issue? Thanks in advance
santosjoni
Postby Dean » Mon Apr 25, 2016 8:53 am
Unfortunately, no. Please use one of the OS listed here: http://helpcenter.onlyoffice.com/server ... ments.aspx
Next
