Enable Mobile browsing
IIS, Apache
Postby nasersobhan » Sun Apr 12, 2015 6:00 am
I have installed version 7.7 onlyoffice server, but when I try my domain on windows it redirects to domain/mobile but it's an unknown URL for onlyoffice.
how can I enable mobile (module, plugin or anything else only office does have) or how can I disable redirection to ./mobile :roll:
thank you in advance. ;)
nasersobhan
Re: Enable Mobile browsing
Postby Dean » Mon Apr 13, 2015 6:35 am
To turn the redirect to /mobile off, please:
1) edit the file c:\Program Files\Ascensio System SIA\ONLYOFFICE\WebStudio\web.appsettings.config (back it up first)
2) find the strings
<add key="mobile.urlregex", <add key="mobile.regex", <add key="mobile.redirect-url", <add key="mobile.redirect-regex" and
3) delete the values from it.
So it looked like:
<add key="mobile.urlregex" value="" />
<add key="mobile.regex" value="" />
<add key="mobile.redirect-url" value="" />
<add key="mobile.redirect-regex" value="" />
Users browsing this forum: Bing [Bot] and 1 guest
