File upload Https port 443 only..?
IIS, Apache
Postby Kpol » Tue Feb 10, 2015 4:15 am
- I have several https urls share on server and i use port map to share same connections. Onlyoffice https i map on port eg. 505 all works exept upload files, if i back on 443 all works again.. Any ideas how i could use another port than 443 and make upload files works?? :?
- Another thing, if i set "Custom domain name" (I am in SSL) it "break" my certificate and if i remove, SSL become normal again... idea?...
User avatar
Kpol
Re: File upload Https port 443 only..?
Postby Eugenie » Fri Feb 27, 2015 1:24 pm
Please see the reply here: viewtopic.php?f=7&t=5674
Eugenie
Postby Kpol » Fri Feb 27, 2015 5:34 pm
Hello, sorry i am on linux... But i think i have a little idea how to do .. ;)
Thanks anyway.
User avatar
Kpol
