[Resolved] HttpS for Linux server
IIS, Apache
Postby Kpol » Sat Feb 07, 2015 7:42 am
I read about SSL and all concern Wind*** servers. Is it possible a guide for Linux Ubuntu Server ?
Thanks.
User avatar
Kpol
[Resolved]: HttpS for Linux server
Postby Kpol » Mon Feb 09, 2015 3:11 pm
... Find by myself ....
Infos : Ubuntu server.
I do this on CLEAN Nginx. After make sure ok for https, then I install Onlyoffice !
Note : Onlyoffice SHOULD use by default a HTTPS! Why ? You see a server host your company infos and project use a NON Crypt url HTTP ?? ... :roll: :roll:
Install OpenSSL:
aptitude install openssl
Create folder for SSL :
mkdir /etc/nginx/yourwebname/
Go inside :
cd /etc/nginx/yourwebname/
Create RSA key 1024bits :
openssl genrsa -out server.key 1024
We create certificat :
openssl req -new -key server.key -out server.csr
(Enter infos you want..)
Create now certificate format x509 by openssl :
openssl x509 -req -days 3650 -in server.csr -signkey server.key -out server.crt
Now we add all keys infos in Nginx by edit
sudo nano /etc/nginx/sites-available/default
remove all inside and add :
server {
   listen 443;
   server_name localhost;
   root html;
   index index.html index.htm;
   ssl on;
   ssl_certificate /etc/nginx/yourwebname/server.crt;
   ssl_certificate_key /etc/nginx/yourwebname/server.key;
   ssl_session_timeout 5m;
   ssl_protocols SSLv3 TLSv1 TLSv1.1 TLSv1.2;
   ssl_ciphers "HIGH:!aNULL:!MD5 or HIGH:!aNULL:!MD5:!3DES";
   ssl_prefer_server_ciphers on;
   location / {
      try_files $uri $uri/ =404;
All should be ok with access to Nginx by https, now install Onlyoffice normally (...)....
Back in Nginx.
sudo nano /etc/nginx/sites-available/onlyoffice
server {
   listen 443;
   root html;
   ssl on;
   location / {
      (!!!This part is generated bu Onlyoffice installation, do not modified it!!!)
Do not forget to restart Nginx server to see change...
Et voila!
User avatar
Kpol
