TALK in Community Edition issues
IIS, Apache
Postby Riebens » Mon Jul 30, 2018 9:23 am
Community Edition 9.6.588
Installed on Windows 2012 R2 server and works fine
After a while, the TALK stops working and always shows Offline - even rebooting the Server does not help.
During Document Edit, the users on a document can still talk to each other.
Ports 5222 and 5280 are open and TeamLabSvc.exe excluded in the antivirus.
If I remove ALL the installations and re-do them, then TALK works for a few hours and then stops working again
Any advice appreciated...
Riebens
FOUND ISSUE: TALK in Community Edition issues
Postby Riebens » Mon Jul 30, 2018 10:28 am
The TeamLabSvc.exe.Config file did not change the default password for Mysql during the install...
updated the password to the correct one, and all is working again.
Riebens
Re: TALK in Community Edition issues
Postby Maxim » Fri Aug 03, 2018 7:33 am
Hello Riebens!
Please check the logs
there should be files like svcJabber.[date].log C:\Program Files (x86)\Ascensio System SIA\CommunityServer\Logs
Also try to restart Onlyoffice Jabber service when the issue repeats.
Postby Riebens » Sat Aug 04, 2018 4:30 pm
Hi Maxim
It was just the password.
All is well thanks
Ben
Riebens
Postby Maxim » Mon Aug 13, 2018 8:19 am
Hello Riebens!
:D
