Change spellchecker's port
IIS, Apache
Postby AMC » Mon Apr 09, 2018 10:17 am
I've installed "OnlyOffice Document Server" on my server, but the 8080 spellchecker's port is already used.
How can i changed the spellchecker's port ?
Thanks for your help.
Regards, AMC
AMC
Re: Change spellchecker's port
Postby Maxim » Fri Apr 27, 2018 10:34 am
Hello AMC!
There is a config onlyoffice-http.conf /etc/nginx/includes
upstream docservice {
  server localhost:8000;
upstream spellchecker {
  server localhost:8080;
upstream example {
  server localhost:3000;
map $http_host $this_host {
    "" $host;
    default $http_host;
map $http_x_forwarded_proto $the_scheme {
     default $http_x_forwarded_proto;
change port
but after update i suppose you will need to edit it again
