Onlyoffice 9 Community Windows - Can't upload files over 2M
IIS, Apache
Postby lextar » Sat Dec 09, 2017 11:18 am
Hi to all,
I installed the latest community server on windows server 2016 and I can't upload files larger than 2 MB in the Documents module.
The error I get is:
request entity too large
I already tried to change some settings in IIS but still have the problem.
lextar
Re: Onlyoffice 9 Community Windows - Can't upload files over
Postby Maxim » Tue Dec 12, 2017 8:18 am
Hello lextar!
Do you try to upload files via localhost?
What did you change?
Postby lextar » Tue Dec 12, 2017 11:27 am
Hello Maxim,
yes, same problem with localhost. With a generic "error" tried uploading a 7M zip file.
I edited the "maximum allowed content length" under "request filtering", see attached file.
Thanks
Schermata 2017-12-12 alle 12.26.17.png (95.54 KiB) Viewed 1611 times
lextar
Postby lextar » Sun Dec 17, 2017 9:20 pm
Any suggestion?
lextar
Postby Maxim » Mon Dec 18, 2017 10:05 am
Hello lextar!
Please try to upload file via IP or domain.
Postby lextar » Tue Dec 19, 2017 9:05 pm
Already tried, I get the same error:
Request entity too large.
lextar
Postby Maxim » Thu Dec 21, 2017 10:38 am
Hello lextar!
I cannot reproduce your issue :cry: . It works as it should.
Did you install ONLYOFFICE Community Edition Win-install.v17.12.166.exe ?
Postby lextar » Thu Dec 21, 2017 11:49 am
No, I'm running an older version.
I'll try to update right now
lextar
Postby Maxim » Thu Dec 21, 2017 12:18 pm
Hello lextar!
Please try to update and inform about result.
Postby lextar » Thu Dec 21, 2017 10:12 pm
Updated right now, I got the same problem :(
Request entity too large with a 3MB .pdf file!
lextar
Next
