HAProxy - Nextcloud with Onlyoffice
IIS, Apache
Postby Ser1ou1 » Tue Nov 28, 2017 4:44 pm
I wanted to build a high availability setup and couldn't get Openoffice to work.
Setup: see attachment.
Https -> Http works very well and i can browse https://nc.xxx.com and https://oo.xxx.com.
But heres the problem: If i want to enable Onlyoffice via the Nextcloud APP it shows an error because OO runs internally with http and give me a timeout error. Accessing from https://nc.xxx.com
How is it possible to let both Web Applications speak via HTTPS on HAProxy, so i can add the OO Server in the NC Interface?
Ser1ou1
Re: HAProxy - Nextcloud with Onlyoffice
Postby Maxim » Thu Nov 30, 2017 8:40 am
Hello Ser1ou1!
I can advice you to look here.
