Integration version has problem with SSL
IIS, Apache
Postby mahdi » Wed Aug 16, 2017 1:41 pm
I installed integrated server.
As soon as I used this server with http it was working fine.
But when I tried to use it under ssl and https, then it just shows a loading picture and can not show the document. What is the reason?
mahdi
Re: Integration version has problem with SSL
Postby Maxim » Thu Aug 17, 2017 6:26 am
Hello mahdi!
Please specify how did you switch server to https? Also specify what instruction did you follow to install Onlyoffice?
Users browsing this forum: Baidu [Spider] and 3 guests
