How to get data result after saving document
Postby jules_diedhiou » Mon May 29, 2017 2:57 pm
I used the php example to integrate onlyoffice in my apps...i want to know how can i get data result after closing doceditor frame.
I want to use this data to make sql script in database?
thanks
<?php
//ini_set('error_reporting', E_ALL);
//require_once "core/class/class_security.php";
include_once 'core/init.php';
require_once 'core/class/class_portal.php';
require_once "core/class/class_functions.php";
require_once "core/class/class_db.php";
require_once "core/class/class_db_pdo.php";
require_once "core/class/class_request.php";
require_once "core/class/class_resource.php";
require_once "core/class/docservers_controler.php";
require_once 'modules/attachments/attachments_tables.php';
require_once 'modules/attachments/class/attachments_controler.php';
$docserverControler = new docservers_controler();
$func               = new functions();
$req                = new request();
$db                 = new Database();
$ac             = new attachments_controler();
 * WebEditor AJAX Process Execution.
require_once( 'modules/content_management/config.php' );
require_once( 'modules/content_management/ajax.php' );
require_once( 'modules/content_management/common.php' );
require_once( 'modules/content_management/functions.php' );
$status = 'ko';
$objectType = '';
$objectTable = '';
$objectId = '';
$appPath = '';
$fileContent = '';
$fileExtension = '';
$error = '';
//$cM = new content_management_tools();
$_trackerStatus = array(
    0 => 'NotFound',
    1 => 'Editing',
    2 => 'MustSave',
    3 => 'Corrupted',
    4 => 'Closed'
 //sendlog("_SESSION CONFIG: " . $_SESSION['config'] ,"logs/webeditor_ajax.log");
$file = $_REQUEST["fileName"];
$IpAddress = $_REQUEST["userAddress"];
$fileExtension = $_REQUEST["extension"];
$userId = $_REQUEST["userID"];
$objectTable = $_REQUEST["objectTable"];
$objectId = $_REQUEST["objectId"];
$objectType = $_REQUEST["objectType"];
$resMaster = $_REQUEST["resMaster"];
$uniqueId = $_REQUEST["uniqueId"];
$docserver = $_REQUEST["docserver"];
$path = $_REQUEST["path"];
//$pathfile = str_replace('#', '/', $path);
$namefile = $_REQUEST["namefile"];
$format = $_REQUEST["format"];
//$fileOnDs = $_REQUEST["fileOnDs"];
sendlog("path:".$path,"logs/webeditor_ajax.log");
if (isset($_GET["type"]) && !empty($_GET["type"])) { //Checks if type value exists
    $response_array;
    @header( 'Content-Type: application/json; charset==utf-8');
    @header( 'X-Robots-Tag: noindex' );
    @header( 'X-Content-Type-Options: nosniff' );
    sendlog(serialize($_GET),"logs/webeditor_ajax.log");
    $type = $_GET["type"];
if ($type=='track'){
    $response_array['status'] = 'success';
     sendlog("Track START","logs/webeditor_ajax.log");
    sendlog("_GET params: " . serialize( $_GET ),"logs/webeditor_ajax.log");
     global $_trackerStatus;
    $data;
    $result["error"] = 0;
    if (($body_stream = file_get_contents('php://input'))===FALSE){
        $result["error"] = "Bad Request";
    $data = json_decode($body_stream, TRUE); //json_decode - PHP 5 >= 5.2.0
    if ($data === NULL){
        $result["error"] = "Bad Response";
   /* if (! isset($_SESSION['collection_id_choice'])
        || empty($_SESSION['collection_id_choice'])
        $_SESSION['collection_id_choice'] = 'letterbox_coll';
        sendlog("_SESSION: " . $_SESSION['collection_id_choice'] ,"logs/webeditor_ajax.log");
    sendlog("_SESSION2: " . $_SESSION['collection_id_choice'] ,"logs/webeditor_ajax.log");*/
    sendlog("InputStream data: " . serialize($data),"logs/webeditor_ajax.log");
    /* $docserver = $docserverControler->getDocserverToInsert($_SESSION['collection_id_choice']);
      if (empty($docserver)) {
        $_SESSION['error'] = _DOCSERVER_ERROR . ' : ' . _NO_AVAILABLE_DOCSERVER . ". " . _MORE_INFOS . ".";
        $location = "";
        sendlog("_SESSION_ERROR_DOCSERVER: " . $_SESSION['error'],"logs/webeditor_ajax.log");
    }else {
    sendlog("_DOCSERVER: " . $docserver ,"logs/webeditor_ajax.log");
    $status = $_trackerStatus[$data["status"]];
    sendlog("_STATUS: " . $status ,"logs/webeditor_ajax.log");
    if($status=='MustSave' or $status=='Closed'){
       /* $_REQUEST['action'] = 'saveObject';
        $_REQUEST['fileContent']=
        $_REQUEST['fileExtension']=$fileExtension;*/
        $fileexplode=explode('(',$file);
        sendlog("EXPLOD: File ".$fileexplode[0].'.'.$fileExtension.'--'.$userId ,"logs/webeditor_ajax.log");
        $pathTmp = $_SESSION['config']['tmppath'];
        $filePathIptmp   = $pathTmp . $file;
        $tmpFileName = 'cm_tmp_file_' . $userId
                . '_' . rand() . '.' . strtolower($fileExtension);
    $filePathOnTmp = $_SESSION['config']['tmppath'] . $tmpFileName ;
    if(rename($file,$tmpFileName)){
        sendlog("SUCCESS rename:"  ,"logs/webeditor_ajax.log");
    }else{
        sendlog("failed rename:"  ,"logs/webeditor_ajax.log");
//sleep(25);
            if (!copy($data["url"] , $filePathOnTmp)) {
                $result = array('ERROR' => _FAILED_TO_COPY_ON_TMP
            . ':' . $filePathIptmp  . ' ' . $filePathOnTmp
        sendlog("ERROR COPY: COPY FAILED "  ,"logs/webeditor_ajax.log");
       // createXML('ERROR', $result);
    }else{
         sendlog("SUCCESS COPY: COPY SUCCESS ".$filePathIptmp.'-'.$filePathOnTmp  ,"logs/webeditor_ajax.log");
    $tmpFilePdfName = 'cm_tmp_file_pdf_' .$userId
               . '_' . rand() . '.pdf';
    $filePathOnTmpPdf = $_SESSION['config']['tmppath'].$tmpFilePdfName;
    $convertedUrl;
    $downloadUrl = $data["url"];
    $key = $data["key"];
    $downloadExtens = '.'.$fileExtension;
    $toExt = '.pdf';
    $percent = GetConvertedUri($downloadUrl, $downloadExtens, $toExt, $key, FALSE, $convertedUrl);
    $downloadUrl =  $convertedUrl;
    sendlog("SUCCESS CONVERTED:  ".$downloadUrl ,"logs/webeditor_ajax.log");
    if (!copy($downloadUrl, $filePathOnTmpPdf )) {
            . ':' . $downloadUrl  . ' ' . $filePathOnTmpPdf
       /* if(file_exists($fileOnDs )){
            unlink($fileOnDs);
    }else{
         sendlog("SUCCESS COPY: COPY SUCCESS ".$downloadUrl.'-'.$filePathOnTmpPdf  ,"logs/webeditor_ajax.log");
    $newfile = $namefile;
    $filePdf = explode('.',$namefile);
    $fileNamepdf = $filePdf[0].'.pdf';
    $fileOnDs = $docserver .$path. $namefile;
    $newfileOnDs = $docserver .$path.  $newfile;
    $PdffileOnDs = $docserver .$path. $fileNamepdf;
    $NewPdfFile = $filePdf[0].'.pdf';
    $newfilePdfOnDs = $docserver .$path.  $NewPdfFile;
    if(file_exists($fileOnDs)){
        unlink($fileOnDs);
        copy($data["url"] , $newfileOnDs);
         sendlog("SUCCESS COPY-- exist docxfileonds: COPY SUCCESS ".$data["url"].'-'.$newfileOnDs ,"logs/webeditor_ajax.log");
    }else{
        sendlog("SUCCESS COPY--not exist docxfileonds: COPY SUCCESS ".$data["url"].'-'.$newfileOnDs ,"logs/webeditor_ajax.log");
    if(file_exists($PdffileOnDs)){
        unlink($PdffileOnDs);
        copy($downloadUrl , $newfilePdfOnDs);
        sendlog("SUCCESS COPY-exist pdffileonds: COPY SUCCESS ".$downloadUrl.'-'.$newfilePdfOnDs ,"logs/webeditor_ajax.log");
    }else{
        sendlog("SUCCESS COPY--not exist pdffileonds: COPY SUCCESS ".$downloadUrl.'-'.$newfilePdfOnDs ,"logs/webeditor_ajax.log");
          sendlog("FILE ON DOCSERVER: ".  $fileOnDs ,"logs/webeditor_ajax.log");
    $_SESSION["doc_id"] = $resMaster;
     include 'modules/content_management/save_attachment_from_cm.php'; //this include not working
      sendlog("test2:".$test2,"logs/webeditor_ajax.log");
     sendlog("upfile tmp_name ".$file ,"logs/webeditor_ajax.log");
     sendlog("upfile tmp_size ".$upfilesize  ,"logs/webeditor_ajax.log");
     sendlog("upfile fileNameOnTmp ".$upfilenameOntmp   ,"logs/webeditor_ajax.log");
     sendlog("upfile extension ".$fileExtension ,"logs/webeditor_ajax.log");
     sendlog("upfile filepdf ".$upfileNamePdfOnTmp,"logs/webeditor_ajax.log");
     sendlog("array allowed:".$docserver,"logs/webeditor_ajax.log");
       switch ($status){
        case "MustSave":
        case "Corrupted":
            $userAddress = $_GET["userAddress"];
            $fileName = $_GET["fileName"];
            $downloadUri = $data["url"];
            $curExt = strtolower('.' . pathinfo($fileName, PATHINFO_EXTENSION));
            $downloadExt = strtolower('.' . pathinfo($downloadUri, PATHINFO_EXTENSION));
            if ($downloadExt != $curExt) {
                $key = getDocEditorKey(downloadUri);
                try {
                    sendlog("Convert " . $downloadUri . " from " . $downloadExt . " to " . $curExt, "logs/webeditor_ajax.log");
                    $convertedUri;
                    $percent = GetConvertedUri($downloadUri, $downloadExt, $curExt, $key, FALSE, $convertedUri);
                    $downloadUri = $convertedUri;
                } catch (Exception $e) {
                    sendlog("Convert after save ".$e->getMessage(),"logs/webeditor_ajax.log");
                    $result["error"] = "error: " . $e->getMessage();
                    echo  $result["error"];
            $saved = 1;
            if (($new_data = file_get_contents($downloadUri))===FALSE){
                $saved = 0;
            } else {
                $storagePath = getStoragePath($fileName, $userAddress);
                file_put_contents($storagePath, $new_data, LOCK_EX);
            $result["c"] = "saved";
            $result["status"] = $saved;
            break;
   sendlog( "track result: " . serialize($result),"logs/webedior-ajax.log");
    //var_dump($result);
     $response_array = $result;
 //$response_array['status'] = 'success';
 die (json_encode($response_array));
/*function track($file,$IpAddress) {
    $data;
        return $result;
        return $result;
    //$data =serialize( $_GET );
    //$fileExtension = $_REQUEST["extension"];
/*$pathTmp = $_SESSION['config']['tmppath'].$IpAddress;
$_SESSION['upfile']['tmp_name']             = $pathTmp .'/'. $file;
$_SESSION['upfile']['size']                 = filesize($pathTmp .'/'. $file);
$_SESSION['upfile']['error']                = "";
$_SESSION['upfile']['fileNameOnTmp']        = $file;
$_SESSION['upfile']['format']               = $fileExtension;
//require_once 'core/docservers_tools.php';
        $location = "";
    }else {
    switch ($status){
        case "MustSave":
        case "Corrupted":
                try {
                    $convertedUri;
                    return $result;
            $saved = 1;
                $saved = 0;
            } else {
            break;
    return $result;
function convert() {
    $fileName = $_GET["filename"];
    $extension = strtolower(pathinfo($fileName, PATHINFO_EXTENSION));
    $internalExtension = trim(getInternalExtension($fileName),'.');
    if (in_array("." + $extension, $GLOBALS['DOC_SERV_CONVERT']) && $internalExtension != "") {
        $fileUri = $_GET["fileUri"];
        if ($fileUri == NULL || $fileUri == "") {
            $fileUri = FileUri($fileName, TRUE);
        $key = getDocEditorKey($fileName);
        $newFileUri;
        $result;
        $percent;
        try {
            $percent = GetConvertedUri($fileUri, $extension, $internalExtension, $key, TRUE, $newFileUri);
            return $result;
        if ($percent != 100)
            $result["step"] = $percent;
            $result["filename"] = $fileName;
            $result["fileUri"] = $fileUri;
            return $result;
        $baseNameWithoutExt = substr($fileName, 0, strlen($fileName) - strlen($extension) - 1);
        $newFileName = GetCorrectName($baseNameWithoutExt . "." . $internalExtension);
        if (($data = file_get_contents(str_replace(" ","%20",$newFileUri)))===FALSE){
            $result["error"] = 'Bad Request';
            return $result;
        } else {
            file_put_contents(getStoragePath($newFileName), $data, LOCK_EX);
        unlink(getStoragePath($fileName));
        $fileName = $newFileName;
    return $result;
function delete() {
    try {
        $filePath = getStoragePath($fileName);
        unlink($filePath);
       sendlog("logs/webedior-ajax.log","Deletion ".$e->getMessage());
        return $result;
jules_diedhiou
Re: How to get data result after saving document
Postby Maxim » Tue May 30, 2017 7:24 am
Hello jules_diedhiou!
Please specify what data do you expect to get? It's not clear for me what exactly you want.
Postby jules_diedhiou » Tue May 30, 2017 10:41 am
Hello
Thanks for reply... I just want to get a $convertedUri and data["url"] to an php file
jules_diedhiou
Postby Maxim » Wed May 31, 2017 9:25 am
You wrote a handler, if you set the address of this handler as a callbackUrl when the editor is initialized, then there will come a request with this data
Return to Notification issues
