problem with SMTP Settings
Postby Yoann » Tue Apr 26, 2016 3:16 pm
since 8.7 community server version, i cannot specify my login for configuring OnlyOffice to use my internal SMTP server
Between the 8.5 and 8.7 you add controls to be sure that the login contain an "@"
But in our office, the login do not contain an "@" (and i think we're not alone).
ONLYOFFICE - Google Chrome.jpg (20.78 KiB) Viewed 3049 times
Can you help me ?
Thanks
Yoann
Re: problem with SMTP Settings
Postby Yoann » Tue May 03, 2016 6:57 am
no one ?
Thanks,
Yoann
Yoann
Postby Alex » Wed May 11, 2016 3:48 pm
Hello
We will surely think of allowing such settings it in our future update.
In your case I would recommend to create a new account with @ for using Onlyoffice smtp
Alex
Postby Yoann » Thu May 12, 2016 9:19 am
thanks for your answer.
I hope it will be fix soon.
Yoann.
Yoann
Return to Notification issues
