Notification error links
Postby JosuéIsmael » Fri Nov 06, 2015 8:53 am
Hello, I wanted to do a little consultation, Can I change the link that users receive in your mails the change projects? because I receive notifications of changes to my projects, I get a wrong link, namely this: (http: // 076be11a8505) Where not take me anywhere, and I should take my web server where I have installed OnlyOffice . I have installed Ubuntu OnlyOffice by docker.
JosuéIsmael
Re: Notification error links
Postby AnaMih » Tue Nov 10, 2015 11:47 am
The issue has been reproduced with some notification types on docker. We are working on solution.
Could you please specify the subject of the message (or make a screenshot of the full message).
User avatar
Postby JosuéIsmael » Tue Nov 10, 2015 11:58 am
AnaMih wrote:The issue has been reproduced with some notification types on docker. We are working on solution.
The message subject is: "News portal for November 3"
All other messages sent by me, and add projects I get with their urls well, but in this type of message with the subject line "News on the portal ..." I get the bad urls, as seen in the following screenshot:
JosuéIsmael
Postby AnaMih » Tue Nov 10, 2015 3:48 pm
Sorry for inconveniences. It will be fixed in the one of next releases.
User avatar
Postby JosuéIsmael » Wed Nov 11, 2015 8:24 am
AnaMih wrote:Sorry for inconveniences. It will be fixed in the one of next releases.
Ie could only be fixed with an update on docker onlyoffice?
JosuéIsmael
Postby AnaMih » Wed Nov 11, 2015 4:21 pm
We'd recommend to try customizing your domain name following the instructions.
(I regret to inform you that we cannot guarantee that it will be a 100% workaround)
If you cannot use custom domain name or it is already being used, unfortunately there is no other alternative solution.
User avatar
Return to Notification issues
