the document editor cannot input east asia fonts!
Postby JerryLia » Thu Aug 06, 2015 1:01 am
Any body know why the documnent editor cannot input the east asia fonts?
Any help will be appreciated!
Jerry
JerryLia
Re: the document editor cannot input east asia fonts!
Postby Dean » Fri Aug 07, 2015 1:01 pm
First check that the hieroglyphs are turned on inside the editor. If it doesn't help, check the fonts to be installed on the server with editors.
Postby JerryLia » Sat Aug 08, 2015 2:52 pm
er......,it seems that there is a little bug when turn on the hieroglyphs and type some east asia charactors,please follow my steps to check it:
1.turn on the hieroglyphs .
2.type some east asia charactors,a alternate input text box can not get nothing after pressing the enter key until it appear next time.I have attach a snapshot to show what has happend to me.
BYW:I am testing the ONLYOffice document server for win(v2.5.7).
The demo (http://api.onlyoffice.com/editors/demopreview#text) works perfectly!
JerryLia
Postby Dean » Tue Aug 11, 2015 8:56 am
What is the font chosen for hierolyphs?
Postby JerryLia » Thu Aug 13, 2015 2:31 pm
It is always like that and never mind what the font is applyed!
JerryLia
Postby JerryLia » Thu Aug 13, 2015 2:33 pm
It always do like that and never mind which font is applyed!
JerryLia
Postby Dean » Fri Aug 14, 2015 11:33 am
The reason of the issue may be that you do not have chinese fonts on the machine where Document Server is installed
In order to resolve the issue, please, set chinese fonts using the package or put tff font to /usr/share/fonts/ directory.
Then run the file: /var/www/onlyoffice/documentserver/Tools/GenerateAllFonts.sh
Clear the browser cache and reopen the page.
After that you should choose the font for your document.
Return to Notification issues
