Bad URL for notification confirm for new user
Postby Kpol » Mon Feb 09, 2015 3:28 pm
Now i use for my server a SSL, but email notification confirm for new user still send in http ... ?
In Settings>Dns setting>Custom DNS>... I enter
https://mydomaine.org
but after "Save" i have only
http://mydomaine.org
inside.... :|
User avatar
Kpol
Re: Bad URL for notification confirm for new user
Postby Dean » Thu Feb 19, 2015 8:47 am
What exactky appears after following the link from the notification? Is the address on the http:// or on the https://?
Postby Kpol » Thu Feb 19, 2015 9:15 am
Update : Sorry! In fact pb doesn't solved ....
I use https://
User avatar
Kpol
Postby cksoft » Sat Mar 25, 2017 2:57 pm
Hello all,
Same problem for me the confirmation link is http:// not https://
Where can i change that ?
Thanks
(I'm using Community server lastest / Docker / Linux ubuntu )
cksoft
Postby Maxim » Mon Mar 27, 2017 6:45 am
Hello cksoft!
Specify please your OnlyOffice server works with SSL? Did you configure Community Server to work with SSL?
Running Community Server using HTTPS protocol
Postby cksoft » Mon Mar 27, 2017 7:22 am
Yes under apache VHOST / Proxy -> Docker container / port 20443
ProxyRequests off
        <Location />
                ProxyPass https://127.0.0.1:20443/
                ProxyPassReverse /
        </Location>
      <IfModule mod_headers.c>
        Header always set Strict-Transport-Security "max-age=15768000; includeSubDomains; preload"
      </IfModule>
Ubuntu 16.04.x SSLABS A+
In general settings / Documents settings
Community Server Address
https://office.mydomain.xxx <- my settings
Exemple: http://office.mydomain.xxx (the exemple)
In general settings / Customise
DNS SETTING
office.mydomain.xxx
The DocumentServer works fine.
Thanks
cksoft
Postby Maxim » Mon Mar 27, 2017 9:43 am
OnlyOffice (Community and Document servers) server works with HTTPS correctly. You have put your certs into /app/onlyoffice/CommunityServer/data/certs/ but the link in email notification still with no https?
Postby cksoft » Mon Mar 27, 2017 9:53 am
Maxim wrote:OnlyOffice (Community and Document servers) server works with HTTPS correctly. You have put your certs into /app/onlyoffice/CommunityServer/data/certs/ but the link in email notification still with no https?
that's exactly what i did :) (volume created with docker container)
sudo docker run --net onlyoffice -i -t -d --restart=always --name onlyoffice-community-server \
   -p 20443:443 \
    -e DOCUMENT_SERVER_PORT_5443_TCP_ADDR=onlyoffice-document-server \
       onlyoffice/communityserver
After i've created a self signed cert and put it in the good folder ...
the files are :
dhparam.pem
onlyoffice.crt
onlyoffice.csr
onlyoffice.key
Everything works fine but i don't understand about this link (chat, crm, etc....)
Ok i can try to solve that with Rewrite Rule but i prefer to correct this issue :)
May be there is a specific file to modify ?
cksoft
Postby Maxim » Mon Mar 27, 2017 11:29 am
Please attach screenshot of the mail with URL for notification if it's possible.
Postby cksoft » Mon Mar 27, 2017 11:55 am
Maxim wrote:Please attach screenshot of the mail if it's possible.
There it is
cksoft
Next
Return to Notification issues
