SMTP Issue
SMTP Issue
Postby sri5 » Thu Oct 09, 2014 1:19 pm
Hi
I assume the smtp Third Party Authorization issue "can't receive the Activation Email" still exists for onlyoffice 7.7
Please let us know if this is fixed and if so how?
Thanks & Regards
Sri
sri5
Re: SMTP Issue
Postby Dean » Fri Oct 10, 2014 3:07 pm
You may find the instruction of setting uop the portal mail here: http://helpcenter.onlyoffice.com/ru/tip ... tings.aspx
Also you can visit the following topic to get the instruction: viewtopic.php?f=4&t=132&p=319&hilit=SMTP#p319
Re: SMTP Issue
Postby jaju » Sun Apr 05, 2015 2:50 pm
I do have one issue while resetting password the password is successfully sent by doesn't received to user end. any notification mail in not sent. it was fine till yesterday. don't know how to solve this issue. please help.
jaju
Re: SMTP Issue
Postby Dean » Wed Apr 15, 2015 11:04 am
to jaju:
Have you changed anything in the portal settings or OS/server configuration?
Re: SMTP Issue
Postby rajkumar » Wed Apr 29, 2015 1:53 pm
Jaju
I too have the same issue, but no solution yet.
rajkumar
Re: SMTP Issue
Postby rajkumar » Wed Apr 29, 2015 2:18 pm
I too have the same issue, please let me know if any solution. SMTP Test mails are working fine, but not receiving notification and new user addition mails.
Regards,
T. Raj Kumar
rajkumar
Re: SMTP Issue
Postby Tyr » Mon May 04, 2015 11:44 pm
Yup, here the same.
When setting the SMTP Settings. my google apps account and my live.com account almost have my onlyoffice server crash when I add my email-account information with port 465 and klick "send test mail".... while the same settings DO work perfect in the mail add-on.
Any suggestions?
Tyr
Re: SMTP Issue
Postby Tyr » Mon May 04, 2015 11:48 pm
+1
system almost crashed when i do a test mail. But the same settings work fine in the mail add-on... ?!?!
Any suggestions? neither smtp.gmail.com nor smtp.live.com I can't get to work.
Tyr
Re: SMTP Issue
Postby Dean » Tue May 05, 2015 11:45 am
Please check the port 587 or 25 (without SSL for 25)
465 doesn't work properly. This bug will be fixed soon.
Return to Notification issues
