Problems with new update
Postby nsicart » Mon May 08, 2017 12:58 pm
I use a 7 inch tablet with windows 10 and I use Onlyoffice because I also use google drive so It keep thing on its place.
With the last update, april the 13th I think, the onlyoffice window is bigger than my 7 inch tablet and it's impossible to work with it!
Is it normal? Will it change?
Thank you
nsicart
Re: Problems with new update
Postby Maxim » Wed May 10, 2017 7:34 am
Hello nsicart!
Please specify what version of OnlyOffice do you use now? What is resolution of your 7 inch tablet?
Can you attach screenshot please how it displays on your 7 inch tablet.
Return to Upgrade
