Document Server upgrade overwrites config
Postby AussieCoder71 » Sun Apr 16, 2017 5:37 am
I'm running document server on UBUNTU 14.04 server with NGINX as my webserver and love using it via nextcloud integration app. I modified my onlyoffice-documentserver.conf to ensure https is used as per the ssl.conf.template instructions. However everytime I upgrade onlyoffice-documentserver using apt-get my configuration gets overwritten and my ssl stops working.
Is the overwriting of onlyoffice-documentserver.conf by design, some sort of problem with my system or an operator error on my part? If it is the way the upgrade is supposed to work, could I write a new onlyoffice-documentserver-local.conf in the include folder so that it is automatically included even after an upgrade?
AussieCoder71
Re: Document Server upgrade overwrites config
Postby Maxim » Wed Apr 19, 2017 8:52 am
Hello AussieCoder71!
We have detected the issue! We will fix it! Thank you!
Postby dataprius » Sun Feb 18, 2018 10:30 am
Hello, we have the same issue and no there are no solution right?
Even more,
After apt-get update and apt-get upgrade appears this:
dpkg: error processing package onlyoffice-documentserver (--configure):
subprocess installed post-installation script returned error exit status 1
Errors where encountered while processing:
I'm using a jessie Debian
Any help?
dataprius
Return to Upgrade
