Export and import projects to another onlyoffice install
Postby lextar » Fri Feb 03, 2017 10:10 am
I need to export all the projects (about 20) from a linux based onlyoffice VM to a new Windows based onlyoffice (community) VM
How can I do that? I already exported and imported the CRM data and now I need to do the same with the Projects.
Any help will be appreciated.
Alex
lextar
Re: Export and import projects to another onlyoffice install
Postby Maxim » Fri Feb 03, 2017 12:57 pm
Hello lextar!
The best way to do that is to use option Backup\Restore in Control Panel. After creating of backup restore it on a new windows installation. First of all i advice you to backup than restore and after restoring make sure that your backup is OK. After restoring only you should kill your old OO server.
Postby lextar » Fri Feb 03, 2017 1:36 pm
Hello Maxim,
I don't have the control panel, i'm running the community edition only.
in the old installation I do have it since it's an old free license, but in the new one no control panel.
lextar
Postby Maxim » Fri Feb 03, 2017 3:02 pm
So, you need to upgrade OnlyOffice Community Edition to Enterprise Edition, than create Backup in Enterprise. After that you can restore Backup on OnlyOffice Windows installation. There is no another way to solve your problem.
Return to Upgrade
