Expand disk space
Expand disk space
Postby kevinb » Wed Jan 10, 2018 5:53 pm
Hey all, I have the latest windows version I installed on a server. I am starting to run a little low on disk space and am going to add another drive, however I can't see any way from within Onlyoffice itself to add storage and make it available to users. How do I go about doing this?? Thanks.
Kevin
kevinb
Re: Expand disk space
Postby Maxim » Thu Jan 11, 2018 12:19 pm
Hello kevinb!
...I can't see any way from within Onlyoffice itself to add storage and make it available to users...
There is no such way. By default all data are stored at C:\Program Files (x86)\Ascensio System SIA\CommunityServer (in version for Windows).
If you want to increase storage space for Onlyoffice with no need to reinstall Onlyoffice you can contact support@onlyoffice.com.
Return to Upgrade
