Onlyoffice does not start after update in June-2017 on Macb
Postby Tredla » Sat Aug 12, 2017 12:38 pm
Dear reader,
I had installed OnlyOffice, because Libreoffice does not handle the .XLSX files correct so I installed it on my Mac in April-2017 and is worked OK, and in june came an update and after that time I could not use it anymore.
I tried to remove and reinstall it, but it there was no difference.
I tried to find the previous version , but no succes.
Therefore my questions, did you had more E-mails or remarks about the same problem and do you have a suggestion to resolve the problem or a link to the previous version of the install file.
I have added 2 screenshots and 1 crash-report after update/installation
Many thanks in advance and I look forward to your answer,
Kind regards Aldert Lukken
Venray, the Netherlands
Here, I have added the crash report::
Process: ONLYOFFICE [577]
Path: /Applications/ONLYOFFICE.app/Contents/MacOS/ONLYOFFICE
Identifier: asc.onlyoffice.ONLYOFFICE
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: ONLYOFFICE [577]
User ID: 501
Date/Time: 2017-08-03 11:43:56.411 +0200
OS Version: Mac OS X 10.10.5 (14F2511)
Report Version: 11
Anonymous UUID: 950C67C1-1196-D731-CA1E-89DF772BAC80
Sleep/Wake UUID: 0A3C2CD6-589D-4F8B-B0C6-EF04B82706D6
Time Awake Since Boot: 2700 seconds
Time Since Wake: 330 seconds
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/libssl.1.1.dylib
Referenced from: /Applications/ONLYOFFICE.app/Contents/Frameworks/libooxmlsignature.dylib
Reason: no suitable image found. Did find:
/Applications/ONLYOFFICE.app/Contents/MacOS/../Frameworks/libssl.1.1.dylib: code signature invalid for '/Applications/ONLYOFFICE.app/Contents/MacOS/../Frameworks/libssl.1.1.dylib'
Binary Images:
0x7fff68372000 - 0x7fff683a892f dyld (353.2.4) <3C068A0D-69D5-3AD6-86D9-6261D3B1564E> /usr/lib/dyld
0x7fff888f4000 - 0x7fff888f9ff7 libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
0x7fff88960000 - 0x7fff88966fff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff88981000 - 0x7fff889adfff libc++abi.dylib (125.1) <B8E6BB31-E27E-3B80-9BA2-73B5AB7E42E1> /usr/lib/libc++abi.dylib
0x7fff889e7000 - 0x7fff88a60fe7 libcorecrypto.dylib (233.30.1) <5779FFA0-4D9A-3AD4-B7F2-618227621DC8> /usr/lib/system/libcorecrypto.dylib
0x7fff88a61000 - 0x7fff88a66fff libsystem_stats.dylib (163.30.2) <4F79A38D-3C9C-3578-8E38-7697F7300CB2> /usr/lib/system/libsystem_stats.dylib
0x7fff88b9f000 - 0x7fff88ba3fff com.apple.TCC (1.0 - 1) <CCA42EE2-3400-3444-9486-BC454E60D944> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff88c46000 - 0x7fff88c62fff com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff89192000 - 0x7fff891bdffb libarchive.2.dylib (30.50.1.1.1) <3E66E4A5-B992-3D94-9218-839B34BDAAA8> /usr/lib/libarchive.2.dylib
0x7fff891cf000 - 0x7fff891d5ff7 libsystem_networkextension.dylib (167.40.3) <BA58B30B-8377-3B0A-8AE3-4F84021D9D4E> /usr/lib/system/libsystem_networkextension.dylib
0x7fff891ed000 - 0x7fff893fdff7 com.apple.CFNetwork (720.5.7 - 720.5.7) <A47D7DD2-5903-39D0-8D27-5A7E2D119D84> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff893fe000 - 0x7fff89541fff libsqlite3.dylib (168.2) <BCB1F77E-2484-3EC4-A1D5-1AE90A407A23> /usr/lib/libsqlite3.dylib
0x7fff89570000 - 0x7fff8959aff7 libdispatch.dylib (442.50.1) <A61E703C-784A-3698-B513-75DD12AAD6DC> /usr/lib/system/libdispatch.dylib
0x7fff8959b000 - 0x7fff8959dfff libRadiance.dylib (1248) <28ECEEB1-E6FD-3152-9344-9786F586A325> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff895ca000 - 0x7fff895d4ff7 com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff89693000 - 0x7fff8969efff libGL.dylib (11.1.6) <38B3FF9A-5660-3080-9DB8-1CAE0E8CD739> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8a060000 - 0x7fff8a063ff7 libdyld.dylib (353.2.4) <224F35C5-6E35-3EC4-A97C-80949CE444E7> /usr/lib/system/libdyld.dylib
0x7fff8a0d1000 - 0x7fff8a0d3ff7 libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8a0d4000 - 0x7fff8a5e9fff com.apple.JavaScriptCore (10600 - 10600.8.7.1) <4C48FD32-ACA3-358F-95D9-05DBB56A1DED> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff8a5ea000 - 0x7fff8a60eff7 com.apple.Sharing (328.17 - 328.17) <AD5E243A-B79F-3D7B-800B-A2C99A1CFEF1> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8a6a1000 - 0x7fff8aaaeff7 libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff8aab8000 - 0x7fff8aab8fff com.apple.CoreServices (62 - 62) <C69DA8A7-B536-34BF-A93F-1C170E2C6D58> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8aab9000 - 0x7fff8aaf4fff com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff8aaf5000 - 0x7fff8ad74ff7 com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff8ad98000 - 0x7fff8ae07fff com.apple.SearchKit (1.4.0 - 1.4.0) <80883BD1-C9BA-3794-A20E-476F94DD89A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8aead000 - 0x7fff8b014ffb com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8b025000 - 0x7fff8b065ff7 libGLImage.dylib (11.1.6) <D6DDC014-2C74-34B3-970A-26F211FF76EF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff8b066000 - 0x7fff8b0fbff7 com.apple.ColorSync (4.9.0 - 4.9.0) <9150C2B7-2E6E-3509-96EA-7B3F959F049E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8b149000 - 0x7fff8b14afff libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
0x7fff8b158000 - 0x7fff8b175fff libsystem_kernel.dylib (2782.70.3) <79B806D6-AEEF-3663-BAE3-2D8A4A0A7A92> /usr/lib/system/libsystem_kernel.dylib
0x7fff8b1f1000 - 0x7fff8b24cff7 libTIFF.dylib (1248) <29AC482A-800E-3E0D-BC91-8211559111C0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8b2d2000 - 0x7fff8b331fff com.apple.AE (681.5 - 681.7) <2BF39455-1CDD-392C-824A-9972C6B1FB57> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8b335000 - 0x7fff8b335fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <B92888D0-ED3F-3430-8F3A-6E56FD16C5F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8b5ad000 - 0x7fff8b64ce27 com.apple.AppleJPEG (1.0 - 1) <6627DDD9-A8FE-3968-B23A-B6A29AA3919A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff8b64d000 - 0x7fff8b910ff7 com.apple.WebKit (10600 - 10600.8.9) <8EE5A9F9-DE98-3202-92C0-23F6E6E5E274> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8ba02000 - 0x7fff8ba73ffb com.apple.ApplicationServices.ATS (360 - 375.4) <888FE0B1-835C-30B1-80AD-5066CADB0364> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8ba74000 - 0x7fff8ba8aff7 libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
0x7fff8bcd1000 - 0x7fff8bd6ffff com.apple.Metadata (10.7.0 - 917.36) <00C4CB5D-E723-3612-84E0-439098392CDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff8bd70000 - 0x7fff8bd72ff7 com.apple.securityhi (9.0 - 55006) <15D38919-9697-3E3A-BCB9-4E3271BC2C7E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8bdf1000 - 0x7fff8be3eff7 com.apple.print.framework.PrintCore (10.3 - 451.1) <DE992474-0841-38A1-B4F6-46D653E454D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8c025000 - 0x7fff8c031ff7 com.apple.OpenDirectory (10.10 - 187) <22FF4721-03D8-381B-AA83-2B07D690C777> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff8cb1d000 - 0x7fff8cb1eff7 libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
0x7fff8cb85000 - 0x7fff8cbc6fff libGLU.dylib (11.1.6) <4BC6579D-A6D0-3A19-880E-E29FAEA698E7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8cc1a000 - 0x7fff8cc1bffb libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
0x7fff8cc4e000 - 0x7fff8cd40ff7 libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
0x7fff8d06d000 - 0x7fff8d07bff7 com.apple.opengl (11.1.6 - 11.1.6) <81B00A5C-ED8A-341F-A11E-1079F7781C21> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8d0a4000 - 0x7fff8d0a4fff com.apple.Accelerate (1.10 - Accelerate 1.10) <F1B96A61-7E4B-31BD-A35B-BA7EF1F16EF4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8d127000 - 0x7fff8d12afff com.apple.IOSurface (97.5 - 97.5) <D09F4452-874E-391D-AAEC-A64F4DD5049E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff8d1f6000 - 0x7fff8d1fdff7 libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
0x7fff8d219000 - 0x7fff8d21dfff libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
0x7fff8d235000 - 0x7fff8d26dfff libsystem_network.dylib (412.20.3) <6105C134-6722-3C0A-A4CE-5E1261E2E1CC> /usr/lib/system/libsystem_network.dylib
0x7fff8d3f2000 - 0x7fff8d6d9ffb com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <8953580E-7857-33B2-AA64-98296830D3A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8d770000 - 0x7fff8d8a0fff com.apple.UIFoundation (1.0 - 1) <466BDFA8-0B9F-3AB0-989D-F9779422926A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff8d8a1000 - 0x7fff8d8b4ff7 com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff8d8b5000 - 0x7fff8d8b7fff libsystem_configuration.dylib (699.40.2) <B19236B6-F772-3861-BB35-44E3B55D0A33> /usr/lib/system/libsystem_configuration.dylib
0x7fff8d8b8000 - 0x7fff8d936fff com.apple.CoreServices.OSServices (640.4 - 640.4) <9D175CD9-B27F-3529-8269-66D8AA83582E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8d937000 - 0x7fff8d957fff com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8d958000 - 0x7fff8d974ff7 libsystem_malloc.dylib (53.30.1) <DDA8928B-CC0D-3255-BD8A-3FEA0982B890> /usr/lib/system/libsystem_malloc.dylib
0x7fff8d975000 - 0x7fff8d977fff libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib
0x7fff8dd54000 - 0x7fff8e5b7ffb com.apple.CoreGraphics (1.600.0 - 790) <7BD274D8-73CC-32DE-BCA5-96C047A3B97B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8e5e8000 - 0x7fff8e623fff com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8e62f000 - 0x7fff8e654ff7 libJPEG.dylib (1248) <412D7F98-5ED5-3D61-BE45-1BE267C7B3D7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8e655000 - 0x7fff8e656ff3 libSystem.B.dylib (1213) <4B24B5BE-45F2-355A-9A35-D438A516D140> /usr/lib/libSystem.B.dylib
0x7fff8e771000 - 0x7fff8e776fff com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8ead6000 - 0x7fff8eae1ff7 libkxld.dylib (2782.70.3) <F5F0305E-A7D5-37CA-945E-E2FB1F8568AC> /usr/lib/system/libkxld.dylib
0x7fff8ebe3000 - 0x7fff8ec85fff com.apple.Bluetooth (4.3.6 - 4.3.6f4) <D9286207-FC6A-36B7-A10D-830F6B1A2E8F> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff8ec86000 - 0x7fff8eca0ff7 com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8eca1000 - 0x7fff8eca1fff com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8ecbb000 - 0x7fff8ecd5ff3 com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff8ef7b000 - 0x7fff8ef95ff7 libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib
0x7fff8ef99000 - 0x7fff8f08cff7 libJP2.dylib (1248) <292199E7-9008-3AB6-9BF2-9C91FF1989BA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8f08d000 - 0x7fff8f091fff libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
0x7fff8f137000 - 0x7fff8f1bbfff com.apple.PerformanceAnalysis (1.0 - 1) <8CC3D6CB-2328-32A5-B70E-174AD408E892> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8f1bc000 - 0x7fff8f1f4fff com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff8f237000 - 0x7fff8f2c0ff7 com.apple.CoreSymbolication (3.1 - 57020.2) <FDAF88F6-7D11-37BC-B758-4B835FA657BA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8f2c1000 - 0x7fff8f2c3fff libCVMSPluginSupport.dylib (11.1.6) <4F965D25-2BC4-372B-BAE1-E833A3C4C3D5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8f2c4000 - 0x7fff8f2c7fff com.apple.xpc.ServiceManagement (1.0 - 1) <A95A15CD-3B21-3513-AFF8-1D7DE3DBFA12> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff8f2e2000 - 0x7fff8f30afff libsystem_info.dylib (459.40.1) <2E16C4B3-A327-3957-9C41-143911979A1E> /usr/lib/system/libsystem_info.dylib
0x7fff8f30b000 - 0x7fff8f30dfff libsystem_sandbox.dylib (358.20.5) <3F5E973F-C702-31AC-97BC-05F5C195683C> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8f30e000 - 0x7fff8f30eff7 liblaunch.dylib (559.40.1) <4F81CA3A-D2CE-3030-A89D-42F3DAD7BA8F> /usr/lib/system/liblaunch.dylib
0x7fff8f30f000 - 0x7fff8f33fff3 com.apple.GSS (4.0 - 2.0) <97F2A028-44CF-3188-B863-F4EEB39CBDBD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff8f9fe000 - 0x7fff8fa07fff libsystem_pthread.dylib (105.40.1) <ACE90967-ECD0-3251-AEEB-461E3C6414F7> /usr/lib/system/libsystem_pthread.dylib
0x7fff8fa08000 - 0x7fff8fa19fff libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
0x7fff8fa1a000 - 0x7fff8fa1dfff com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8fa79000 - 0x7fff8fa82ff7 libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
0x7fff8fdac000 - 0x7fff8fe13ffb com.apple.datadetectorscore (6.0 - 396.1.2) <7D88DC30-2583-35A6-8342-425201FE7044> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8fef3000 - 0x7fff8ff5aff7 com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8ff5b000 - 0x7fff9022aff3 com.apple.CoreImage (10.3.5) <0224F5A6-636A-374B-B46C-13E066596725> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff9022b000 - 0x7fff90236ff7 com.apple.CrashReporterSupport (10.10 - 631) <C44259AC-0A1C-3EC5-99AC-48CB520A709D> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff90237000 - 0x7fff90237ff7 libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
0x7fff9028e000 - 0x7fff90593ff3 com.apple.HIToolbox (2.1.1 - 758.7) <B1188DED-5E71-3AB4-9E57-67F84C116ECE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff905b3000 - 0x7fff90798ff7 libicucore.A.dylib (531.51) <5AFEE55D-9BDD-362C-8A3C-A42237A96169> /usr/lib/libicucore.A.dylib
0x7fff907a6000 - 0x7fff907b3fff libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib
0x7fff907ee000 - 0x7fff90866ff7 com.apple.SystemConfiguration (1.14.4 - 1.14) <B835C014-901E-37B7-BD09-2EFF5FFEB910> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff908df000 - 0x7fff908e4ffb libheimdal-asn1.dylib (398.40.1) <7D2BE3DE-60F7-3A6E-A92E-DA0EF9D3417E> /usr/lib/libheimdal-asn1.dylib
0x7fff908e5000 - 0x7fff909d7ff7 libxml2.2.dylib (26.15) <B587DA25-360B-3742-BE9A-04B171504D79> /usr/lib/libxml2.2.dylib
0x7fff90ac1000 - 0x7fff90ac9fff libsystem_dnssd.dylib (576.50.2) <9EC5AF92-D0D2-3BDE-92B6-D3730D3865C8> /usr/lib/system/libsystem_dnssd.dylib
0x7fff90aca000 - 0x7fff90adaff7 libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
0x7fff90adb000 - 0x7fff90bf2fe7 libvDSP.dylib (516) <DFEDB210-49D1-3803-88A2-C61DB6A45C3D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff90bf3000 - 0x7fff90c05ff7 com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff90c06000 - 0x7fff90c06ff7 libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
0x7fff90d52000 - 0x7fff90d5dfff libcommonCrypto.dylib (60061.30.1) <E789748D-F9A7-3CFF-B317-90DF348B1E95> /usr/lib/system/libcommonCrypto.dylib
0x7fff90d5e000 - 0x7fff90d6bff7 libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
0x7fff90d84000 - 0x7fff90dbeffb com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff90dbf000 - 0x7fff90dccff7 com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff911a5000 - 0x7fff91231fef libsystem_c.dylib (1044.40.3) <2E673D96-E334-37D2-833A-E57383BBA377> /usr/lib/system/libsystem_c.dylib
0x7fff91232000 - 0x7fff912c6fff com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff912c7000 - 0x7fff912d6fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff91398000 - 0x7fff913e9fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <8E6AE326-9F3E-3182-BD9E-FDF561211E2E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff91445000 - 0x7fff91466fff com.apple.framework.Apple80211 (10.3 - 1030.71.6) <C0A17391-5C8B-34B1-BD46-8D644AB57DE0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff91467000 - 0x7fff918bafc7 com.apple.vImage (8.0 - 8.0) <33BE7B31-72DB-3364-B37E-C322A32748C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff918c2000 - 0x7fff91934fff com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff91cab000 - 0x7fff91fdcff7 com.apple.Foundation (6.9 - 1154.20) <3D37F9B8-96CC-324B-9062-0A7E4ABCDC1F> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff920ec000 - 0x7fff92117ff7 com.apple.DictionaryServices (1.2 - 229.1) <62EC3E1B-5A28-3252-90FF-C2E9999C2A2A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff92183000 - 0x7fff92194ff7 libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
0x7fff921ec000 - 0x7fff92d6dff7 com.apple.AppKit (6.9 - 1348.17) <E485D56D-3E72-34B7-99BB-BFDEE2D07BF5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff92d6e000 - 0x7fff92d72ff7 libGIF.dylib (1248) <C0BB32AD-9E76-3DF1-ABD7-C856D44E7C23> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff93110000 - 0x7fff93110fff com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff93209000 - 0x7fff9320afff libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff93262000 - 0x7fff9328afff libxpc.dylib (559.40.1) <5C829202-962E-3744-8B50-00D38CC88E84> /usr/lib/system/libxpc.dylib
0x7fff9335e000 - 0x7fff93362fff com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff93394000 - 0x7fff93408ffb com.apple.securityfoundation (6.0 - 55126) <7BC5EB97-2BC8-390D-AC93-C36C456F1126> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff93409000 - 0x7fff9342eff7 libPng.dylib (1248) <0D88B42A-FEDC-3F51-ADC3-2A426699CC1A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff9342f000 - 0x7fff93489ff7 com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff93dd0000 - 0x7fff93de7ff7 libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff93e3f000 - 0x7fff93f63ff7 com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff93f67000 - 0x7fff93f69fff com.apple.loginsupport (1.0 - 1) <DAAD7013-A19D-3858-BFF7-DE1DAF664401> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff93f83000 - 0x7fff93f9cff7 com.apple.CFOpenDirectory (10.10 - 187) <F1805A0F-D5CC-35A8-9349-042D58D128B0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff93f9d000 - 0x7fff940dafff com.apple.ImageIO.framework (3.3.0 - 1247) <001CB61C-6BDE-30A1-ACB7-C537E0043DF6> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff940db000 - 0x7fff940e3ff3 com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff940e4000 - 0x7fff94294ffb com.apple.QuartzCore (1.10 - 361.19) <973C2AD1-9D22-3F1F-A291-84B1F677C50D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff94295000 - 0x7fff942beff3 libxslt.1.dylib (13.13) <18F488CB-AA53-3503-A199-044CA7664DE5> /usr/lib/libxslt.1.dylib
0x7fff942bf000 - 0x7fff942dfff7 com.apple.MultitouchSupport.framework (264.6 - 264.6) <79E327E8-AA72-346D-8B5E-8BAC56FC17A5> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff942e7000 - 0x7fff9467fff7 com.apple.CoreFoundation (6.9 - 1153.31) <4151A95B-66CA-3E6F-9FB2-DF1D8F3E606A> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff94b9a000 - 0x7fff94bb3ff3 com.apple.openscripting (1.6.4 - 162.2) <BF79207B-C762-346D-8FF0-3DDCECC9E9E2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff94ce4000 - 0x7fff95017ff7 libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib
0x7fff9511d000 - 0x7fff9511dfff com.apple.audio.units.AudioUnit (1.12 - 1.12) <E5335492-7EFE-31EA-BE72-4A9CEE68D58E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff9511e000 - 0x7fff95164ff7 libFontRegistry.dylib (134.1) <CE41D8C2-BEED-345C-BC4F-3775CC06C672> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff95165000 - 0x7fff95166fff liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
0x7fff95167000 - 0x7fff9536146f libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib
0x7fff95386000 - 0x7fff95446ff7 com.apple.backup.framework (1.6.5 - 1.6.5) <86396038-33EA-3046-9F70-093A3D6407D4> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff9545a000 - 0x7fff954a9ff7 com.apple.opencl (2.4.2 - 2.4.2) <BF5E999C-5710-362E-95E8-86EE7BEA357C> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff954aa000 - 0x7fff954d7fff com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff9550a000 - 0x7fff95525ff7 libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
0x7fff955d4000 - 0x7fff9571cff7 com.apple.WebKitLegacy (10600 - 10600.8.9) <9F1ED8A5-1AB9-333C-B1A1-E13485F12E53> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff9571d000 - 0x7fff95721fff libCoreVMClient.dylib (79.1) <201EF6DF-5074-3CB7-A361-398CF957A264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff9577d000 - 0x7fff95785fff libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
0x7fff957d4000 - 0x7fff95a4afff com.apple.security (7.0 - 57031.40.9) <8D9CB878-BB71-3CF1-88CE-9E6FAC4043ED> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff95a4b000 - 0x7fff95a54fff libGFXShared.dylib (11.1.6) <10DBFA0B-1484-3723-BFD3-7D184CC5A2E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff95b8c000 - 0x7fff95b8cfff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff95b8d000 - 0x7fff95b93fff libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib
0x7fff95bbb000 - 0x7fff95cd4ff3 com.apple.CoreText (454.11 - 454.14) <B3B308C3-F4B8-3776-9B78-8E94D4E74D0A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff95e3b000 - 0x7fff96dfeff3 com.apple.WebCore (10600 - 10600.8.9) <A5400B08-6067-370E-B224-14890DA39857> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff96e34000 - 0x7fff96e34fff libOpenScriptingUtil.dylib (162.2) <D6A2216D-ADB2-3F24-AD30-F6D00829F545> /usr/lib/libOpenScriptingUtil.dylib
0x7fff96e35000 - 0x7fff96ef8ff7 libvMisc.dylib (516) <21497A28-8DCB-3EB8-BDAC-93C93382B0AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff96ef9000 - 0x7fff96f3fff7 libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
0x7fff97067000 - 0x7fff970d5ff3 com.apple.Heimdal (4.0 - 2.0) <8D1667CF-D454-3E07-A58E-E15591B5A95E> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff973ae000 - 0x7fff973faff7 libcups.2.dylib (408.2) <E8AD18F9-61E4-3791-B840-504468C25556> /usr/lib/libcups.2.dylib
0x7fff974ca000 - 0x7fff97536fff com.apple.framework.CoreWLAN (5.0 - 500.35.2) <03697149-1CDD-32FF-B564-1C1EF5E9E5C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff97537000 - 0x7fff9765fff7 com.apple.coreui (2.1 - 308.6) <9E0E9C6A-68F5-34C1-A17C-96226D401D4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff97660000 - 0x7fff9767bfff com.apple.AppleVPAFramework (1.4.5 - 1.4.5) <313A0FA8-C12F-30C1-A33D-9A48E3C0594E> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff976a8000 - 0x7fff976f2fff com.apple.HIServices (1.22 - 523) <99ADA325-53C8-368E-A5FA-3F913CD2245A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff976f3000 - 0x7fff976fafff com.apple.NetFS (6.0 - 4.0) <C263C8F8-F284-3101-AC82-A97A81716063> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff976fb000 - 0x7fff97715ff7 liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
0x7fff97716000 - 0x7fff9771fff3 com.apple.CommonAuth (4.0 - 2.0) <9A484EE6-0003-3AB1-AE4F-AA543BBBF53F> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff97786000 - 0x7fff977acfff com.apple.ChunkingLibrary (2.1 - 163.6) <29D4CB95-42EF-34C6-8182-BDB6F7BB1E79> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff977ad000 - 0x7fff977beff3 libsystem_coretls.dylib (35.40.1) <155DA0A9-2046-332E-BFA3-D7974A51F731> /usr/lib/system/libsystem_coretls.dylib
0x7fff977c1000 - 0x7fff977c6ff7 libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
0x7fff97879000 - 0x7fff97885fff com.apple.speech.synthesis.framework (5.3.11 - 5.3.11) <DFC7FD85-F1B0-317C-8513-722570CB8FB9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff978bc000 - 0x7fff97910fff libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
0x7fff97993000 - 0x7fff97994ff7 com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff97a51000 - 0x7fff97a81fff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
0x7fff97a82000 - 0x7fff97a9fffb libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
0x7fff97aa0000 - 0x7fff97ed0fff com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff97ed1000 - 0x7fff97fc5fff libFontParser.dylib (134.11) <798C2BA2-B3D3-39B5-981C-20B42258BAB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff97fc6000 - 0x7fff980d5ff3 com.apple.desktopservices (1.9.3 - 1.9.3) <FEE11342-5BC4-37A7-8169-DA48BE17B9C9> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff980ef000 - 0x7fff980f7ffb libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
0x7fff980f8000 - 0x7fff98286fff libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
Model: MacBook5,1, BootROM MB51.007D.B03, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.32f8
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54333531533641465238432D47372020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.3.6f4 17916, 3 services, 19 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Crucial_CT128MX100SSD1, 128,04 GB
Serial ATA Device: HL-DT-ST DVDRW GS21N
USB Device: Built-in iSight
USB Device: HP X1200 USB Optical Mouse
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
Thunderbolt Bus:
screenshot 2
Apple Schermafbeelding 2017-08-03 om 11.53.42.png (54.86 KiB) Viewed 803 times
screenshot 1
Schermafbeelding 2017-08-03 om 09.51.36.png (62.28 KiB) Viewed 803 times
Tredla
Re: Onlyoffice does not start after update in June-2017 on M
Postby Maxim » Mon Aug 14, 2017 8:00 am
Hello Tredla!
Please send (show) us content of Frameworks folder - /Applications/ONLYOFFICE.app/Contents/Frameworks
Here you can download previous version of Onlyoffice Desktop Editors.
Postby Tredla » Sun Aug 20, 2017 9:44 am
Hello Maxim,
Thanks for your answer and excuse for the long delay, but I made screenshots of the content of the frameworks folder ( see 2 zip file attachments, the timestamp is the sequence ), thereafter I de-installed ONLYOFFICE and installed 4.3 version and it worked OK!!.
I hope this was the information you asked for and if not let me know how to create the info so can reproduce it in the correct way.
Thank you once more for your help.
Regards Tredla
Maxim wrote:Hello Tredla!
Schermafbeelding 2017-08-20 om 09.36.57-k.zip
(122.37 KiB) Downloaded 26 times
Schermafbeelding 2017-08-20 om 09.35.26-k.zip
(169.26 KiB) Downloaded 30 times
Tredla
Postby Maxim » Mon Aug 21, 2017 8:04 am
Hello Tredla!
Thank you for the information, we are trying to fix.
Return to Upgrade
