разворачиваем бекап
Установка и первый запуск
разворачиваем бекап
Сообщение damir » Ср ноя 30, 2016 2:34 pm
После разворота бекапа на новый сервер, выдает ошибку:
Server Error in '/' Application.
Unknown column 'p.affiliate_id' in 'field list'
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: MySql.Data.MySqlClient.MySqlException: Unknown column 'p.affiliate_id' in 'field list'
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[MySqlException (0x80004005): Unknown column 'p.affiliate_id' in 'field list']
   MySql.Data.MySqlClient.MySqlStream.ReadPacket() +444
   MySql.Data.MySqlClient.NativeDriver.GetResult(Int32& affectedRow, Int64& insertedId) +468
   MySql.Data.MySqlClient.Driver.NextResult(Int32 statementId, Boolean force) +136
   MySql.Data.MySqlClient.MySqlDataReader.NextResult() +1217
   MySql.Data.MySqlClient.MySqlCommand.ExecuteReader(CommandBehavior behavior) +2578
   MySql.Data.MySqlClient.MySqlCommand.ExecuteDbDataReader(CommandBehavior behavior) +9
   System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader() +17
   ASC.Common.Data.DataExtensions.ExecuteListReader(IDbCommand command) +104
   ASC.Core.Data.DbBaseService.ExecList(ISqlInstruction sql) +87
   ASC.Core.Data.DbTenantService.GetTenants(Exp where) +29
   ASC.Core.Data.DbTenantService.GetTenant(String domain) +215
   ASC.Core.Caching.CachedTenantService.GetTenant(String domain) +221
   ASC.Core.TenantManager.GetTenant(String domain) +125
   ASC.Core.TenantManager.GetCurrentTenant(Boolean throwIfNotFound) +260
   ASC.Web.Studio.Core.WarmUp..ctor() +125
   ASC.Web.Studio.Core.WarmUp..cctor() +84
[TypeInitializationException: The type initializer for 'ASC.Web.Studio.Core.WarmUp' threw an exception.]
   ASC.Web.Studio.MainPage.get_RedirectToStartup() +187
   ASC.Web.Studio.MainPage.Page_PreInit(Object sender, EventArgs e) +80
   ASC.Web.Studio._Default.OnPreInit(EventArgs e) +116
   System.Web.UI.Page.PerformPreInit() +49
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1844
в интернете нашел такое решение:
http://dev.onlyoffice.org/viewtopic.php?f=1&t=6833
но оно не помогло и не подошло.
и в нем так же не понял, почему нужно именно в таблицу:
'tenants_partners'
может быть дело в том, что бекап от версии 8.1, а на новый сервер поставил 8.7.1?
Тогда как развернуть этот бекап на новую версию 8.7.1?
damir
Re: разворачиваем бекап
Сообщение Ivan » Ср ноя 30, 2016 4:01 pm
Здравствуйте!
Вы правы, проблема в том, что бекап был выполнен на предыдущей версии ПО.
Вам нужно установить версию 8.1, развернуть бекап, а потом обновиться до новой версии через инсталлятор.
В данный момент последняя версия 8.9.1, рекомендуем Вам установить ее.
Спасибо за интерес к нашему продукту.
Сообщение damir » Чт дек 01, 2016 1:12 pm
А как правильно сделать бекап на 8.1?
damir
Сообщение Ivan » Чт дек 01, 2016 3:29 pm
Чтобы выполнить бэкап на Windows версии зайдите на портал, откройте модуль Настройки > Резервное копирование. Выберите временное хранилище, Вам будет предоставлена ссылка на скачивание заархивированного бекапа.
Развернуть бэкап через настройки Вы можете в Onlyoffice Enterprise Edition. Для этого надо загрузить архив в общие документы, а затем открыть модуль Панель управления > Восстановление данных и выбрать файл бекапа. Подробная инструкция здесь.
Если Вы пользутесь Community Edition, файлы для бекапа по умолчанию находятся здесь :
c:\Program Files\Ascensio System SIA\ONLYOFFICE\Data\
c:\Program Files\Ascensio System SIA\ONLYOFFICE\WebStudio\
Сообщение damir » Пн дек 05, 2016 12:40 pm
Хорошо.
А где можно скачать 8.1.
Чтобы перенести базу на новый сервер с onlyoffice 8.1 windows communityserver. А потом уже там сделать апгрейд на повышение версии портала. При скачивание с сайта, скачивается 8.9.1
damir
Сообщение Ivan » Пн дек 05, 2016 12:45 pm
Все доступные версии Commuтity Server находятся по этой ссылке.
Сообщение pecimom » Пт дек 23, 2016 7:47 am
Доброе утро
при восстановлении из бекапа (Commuтity Server 8.5, windows) пропали пользователи,тоесть я смотрю при помощи MySQL Workbench и вижу что в таблице core_user есть пользователи, но при попытке зайти под кем то из них, получаю ошибку (пользователь не найден), перенес папки(data и webstudio) полностью.
Подскажите пожалуйста как решить эту проблему
заранее огромное спасибо
pecimom
Сообщение Ivan » Пт дек 23, 2016 1:54 pm
Здравствуйте!
Пожалуйста уточните следующие моменты:
- на какой версии ONLYOFFICE было выполнено резервное копирование
- на какой версии и каким способом Вы развернули бекап
