Nextcloud. Удаление Onlyoffice.
Сообщение sanrega » Ср июн 21, 2017 5:43 pm
Здравствуйте. Установил по инструкции, потом удалил. В списке приложений Onlyoffice отсутствует, в папке с Nextcloud его тоже нет. Тем не менее, что-то осталось, т.к. логи стабильно пестрят ошибками:
Error no app in context OCP\AppFramework\QueryException: Could not resolve OCA\Onlyoffice\AdminSettings! Class OCA\Onlyoffice\AdminSettings does not exist
/var/www/lib/private/AppFramework/Utility/SimpleContainer.php - line 117: OC\AppFramework\Utility\SimpleContainer->resolve('OCA\\Onlyoffice\\...')
/var/www/lib/private/ServerContainer.php - line 132: OC\AppFramework\Utility\SimpleContainer->query('OCA\\Onlyoffice\\...')
/var/www/lib/private/Settings/Manager.php - line 261: OC\ServerContainer->query('OCA\\Onlyoffice\\...')
/var/www/lib/private/Settings/Manager.php - line 352: OC\Settings\Manager->query('OCA\\Onlyoffice\\...')
/var/www/settings/Controller/AdminSettingsController.php - line 138: OC\Settings\Manager->getAdminSettings('server')
/var/www/settings/Controller/AdminSettingsController.php - line 72: OC\Settings\Controller\AdminSettingsController->getNavigationParameters('logging')
[internal function] OC\Settings\Controller\AdminSettingsController->index('logging')
/var/www/lib/private/AppFramework/Http/Dispatcher.php - line 160: call_user_func_array(Array, Array)
/var/www/lib/private/AppFramework/Http/Dispatcher.php - line 90: OC\AppFramework\Http\Dispatcher->executeController(Object(OC\Settings\Controller\AdminSettingsController), 'index')
/var/www/lib/private/AppFramework/App.php - line 114: OC\AppFramework\Http\Dispatcher->dispatch(Object(OC\Settings\Controller\AdminSettingsController), 'index')
/var/www/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47: OC\AppFramework\App main('OC\\Settings\\Con...', 'index', Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
[internal function] OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
/var/www/lib/private/Route/Router.php - line 299: call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
/var/www/lib/base.php - line 1000: OC\Route\Router->match('/settings/admin...')
/var/www/index.php - line 40: OC handleRequest()
{main}
Nextcloud у меня установлен в корне /var/www, если это имеет значение. Вопрос - как удалить остатки Onlyoffice? Где искать причину ошибок в логах связанных с ним?
sanrega
Re: Nextcloud. Удаление Onlyoffice.
Сообщение Maxim » Пн июн 26, 2017 10:06 am
День добрый sanrega!
Уточните по какой инструкции устанавливали Onlyoffice а также как удаляли.
